Agilent SVM3500用户指南
消耗积分:0 | 格式:rar | 大小:371 | 2010-01-08
laoyelang
分享资料个
Main Features
• 6U single slot VME/VXS (VITA 41) module
• Quad-channel 12-bit 500 MS/s ADC
• Dual 12-bit 1GS/s and single 12-bit 2GS/s
configuration possibilities
• External clock distributed by an in-house developed low
jitter chipset
• One Xilinx® Virtex-5 FPGA providing on board FIR for
interleaving mismatch correction
• Lookup table providing data correction
• Two Xilinx Virtex-4 FPGAs for real-time signal
processing and data flow control
• Two on-board DDR2 SDRAM banks, 32 Mwords, each
64-bit wide, for a total of 512 MB processing memory
• Tundra TSI148 VME bus interface, VME64x and
2eSST compliant
• VXS VITA 41.0 compliant, 8x 3.125 Gbps serial I/O links on P0 connector
• Two front panel SFP slots for up to 3.125 Gbps fiber or
copper transceivers
• Auxiliary I/O mezzanine with multipurpose 12-bit
65 MS/s ADC, 12-bit 130 MS/s DAC, and 14 digital
front-panel I/O ports
• External trigger input
• High-speed digital I/O on P0 and P2 user-defined I/O
• Firmware Development Kit containing FPGA interface
cores, software, and reference design
• FPGA-based VXS and optical data link interfaces for
easier adaptation to different protocols
• Local FLASH memory to store multiple FPGA bitstreams
for complex, multimode applications
• Device drivers for Windows®, VxWorks®, and Linux®
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
