MM54HC237/MM74HC237 3-to-8 Line Decoder With Address Latches General Description These devices utilize advanced silicon-gate CMOS technology, to implement a three-to-eight line decoder with latches on the three address inputs. When GL goes from low to high, the address present at the select inputs (A, B and C) is stored in the latches. As long as GL remains high no address changes will be recognized. Output enable controls, G1 and G2, control the state of the outputs independently of the select or latch-enable inputs. All of the outputs are low unless G1 is high and G2 is low. The 'HC237 is ideally suited for the implementation of glitch-free decoders in storedaddress applications in bus oriented systems. The 54HC/74HC logic family is speed, function and pin-out compatible with the standard 54LS/74LS logic family. All inputs are protected from damage due to static discharge by diodes to VCC and ground. Features Y Typical propagation delay: 20 ns Y Wide supply range: 2±6V Y Latched inputs for easy interfacing Y Fanout of 10 LS-TTL loads
