MC34727,pdf datasheet (600mA H
消耗积分:2 | 格式:rar | 大小:444 | 2010-01-12
李鸿洋
分享资料个
The 34727 is a high efficiency, low quiescent current (IQ), synchronous buck regulator, implementing Freescale’s innovative
Z-mode architecture. Freescale’s Z-mode architecture greatly improves the ripple performance during light load currents, but still maintains a low quiescent current of 65μA, at no load in “Sleepy” Z-mode.
The 34727 accepts an input voltage in the range of 2.7 to 5.5V, making it ideally suited for single cell Li-Ion based applications. Factory preset output voltages, ranging from 0.8 to 3.3V, reduce the number of required auxiliary components. The part is able to provide 600mA of continuous load current across the input and the output voltage ranges.
The 34727 switches at 2.0MHz to allow the use of small surface mount inductors and capacitors, to save precious board space.
The 34727 is available in the small, space saving, and low cost, 2x2 UDFN-8 packages. The part is guaranteed for operation over the -25°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
