Slots in Planes-Don't Use
消耗积分:0 | 格式:rar | 大小:444 | 2010-01-15
87430416
分享资料个
Has this ever happened to you? The board is finished.
The traces are tightly routed and you have done a magnificent
job of confining them to the fewest possible number of
signal trace layers. Then the engineer calls and tells you he
has forgotten one little thing--just one little net that happens
to run horizontally across the entire board! It will take
hours to tweak hundreds of other traces to fit this one in.
But, just one little slot in an adjacent ground plane would
make room for it and you would be done in minutes. And,
after all, it is the engineer's fault, not yours, that you have to
create this little slot!
Tempting, isn't it? Well, don't do it! This article will
give you three reasons why slots in planes are to be avoided on high speed boards.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
