74LS138/54LS138 pdf datasheet
消耗积分:10 | 格式:rar | 大小:133 | 2008-08-06
385288
分享资料个
54LS138/DM54LS138/DM74LS138,
54LS139/DM54LS139/DM74LS139
Decoders/Demultiplexers
General Description
These Schottky-clamped circuits are designed to be used in
high-performance memory-decoding or data-routing applications,
requiring very short propagation delay times. In
high-performance memory systems these decoders can be
used to minimize the effects of system decoding. When
used with high-speed memories, the delay times of these
decoders are usually less than the typical access time of the
memory. This means that the effective system delay introduced
by the decoder is negligible.
The LS138 decodes one-of-eight lines, based upon the conditions
at the three binary select inputs and the three enable
inputs. Two active-low and one active-high enable inputs
reduce the need for external gates or inverters when expanding.
A 24-line decoder can be implemented with no external
inverters, and a 32-line decoder requires only one
inverter. An enable input can be used as a data input for
demultiplexing applications.
The LS139 comprises two separate two-line-to-four-line decoders
in a single package. The active-low enable input can
be used as a data line in demultiplexing applications.
All of these decoders/demultiplexers feature fully buffered
inputs, presenting only one normalized load to its driving
circuit. All inputs are clamped with high-performance
Schottky diodes to suppress line-ringing and simplify system
design.
Features
Y Designed specifically for high speed:
Memory decoders
Data transmission systems
Y LS138 3-to-8-line decoders incorporates 3 enable inputs
to simplify cascading and/or data reception
Y LS139 contains two fully independent 2-to-4-line decoders/
demultiplexers
Y Schottky clamped for high performance
Y Typical propagation delay (3 levels of logic)
LS138 21 ns
LS139 21 ns
Y Typical power dissipation
LS138 32 mW
LS139 34 mW
Y Alternate Military/Aerospace devices (54LS138,
54LS139) are available. Contact a National Semiconductor
Sales Office/Distributor for specifications.
评论(0)
发评论
下载排行榜
