The ITE9611 is a low-voltage, fast turn on, single NMOSFTE high-side power switch. the typical rise time is
1ms. This IC can operate over an input voltage range of 2.0V to 5.5V. A 65mΩ (typ.) ultra-low switch-on
resistance and 35uA low quiescent current are realized in the Device.
Integrating many function circuits, such as, current limit circuit, short circuit protection circuit and thermal
shutdown circuit, the ITE9611 can provide a good performance to protect the power source from over current
and short circuit conditions. Besides, Building internal soft-start minimizes stress on the input power source by
reducing capacities inrush current during start-up time. Furthermore, Owning
____
OC
fault flag output that
embedded delay time function can indicate fault conditions correctly. Those abilities make the ITE9611 to be
an ideal solution for USB power supply applications.
下载资料需要登录,并消耗一定积分。
