HT82V738 pdf datasheet (24-Bit
消耗积分:3 | 格式:rar | 大小:444 | 2008-08-06
李勇
分享资料个
The HT82V738 is a high performance audio DAC converter.
It provides digital de-emphasis (32, 44.1 and
48kHz), external mute control and adjustment for serial
data and clock. The HT82V738 accepts data at audio
rates up to 96kHz. It performs within a wide dynamic
range, high SNR ratio and has low clock jitter sensitivity.
HT82V738 is an ideal DAC for DVD players, MP3 players
and set-top box systems. It is also pin-compatible
with CS4340.
评论(0)
发评论
下载排行榜
