AAT4614,pdf datasheet(Adjustab
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-29
李娟
分享资料个
The AAT4614 SmartSwitch is a current limited P-channel MOSFET power switch designed for high side load switching applications. This switch operates with inputs ranging from 2.4V to 5.5V, making it ideal for both 3V and 5V systems. An integrated current-limiting circuit protects the input supply against large currents which may cause the supply to fall out of regulation. Reverse current blocking is provided to protect the load switch from reverse current potentials while the device is shutdown.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
