AAT4620,pdf datasheet(PCMCIA C
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-29
张艳
分享资料个
The AAT4620 SmartSwitch is a current limited Pchannel MOSFET power switch designed for highside load-switching applications in PCMCIA GSM/GPRS/3G modem cards. Used in conjunction with a super capacitor, the AAT4620 will ensure that the power ratings of the PCMCIA host are not exceeded at any time. Featuring two independent, programmable current limits and a power loop, the AAT4620 can ensure that the super capacitor can be charged without exceeding PCMCIA specifications. The current limit is set by two external resistors allowing a ±10% current limit accuracy over the normal operating temperature range. The switch can be controlled from either of the two enable inputs and in the off condition will block currents in both directions. The AAT4620 also incorporates a System READY function which can advise the system that the super capacitor is fully charged and ready for use. Adjustable hysteresis is provided with the addition of an external resistor. The quiescent supply current is typically a low 40μA. In shutdown mode, the supply current decreases to less than 1μA.
评论(0)
发评论
下载排行榜
