AAT4687,pdf datasheet(Over-Vol
消耗积分:10 | 格式:rar | 大小:221 | 2010-01-29
h1654155275.0032
分享资料个
The AAT4687 OVPSwitch™ is a member of AnalogicTech’s Application Specific Power MOSFET™ (ASPM™) product family. It is a P-channel MOSFET power switch with precise
over-voltage protection control, designed to protect low-voltage systems against high-voltage faults up to +28V. If the input voltage exceeds the programmed over-voltage threshold, the P-channel MOSFET switch will be turned off to prevent the output load circuits from damage. The AAT4687 is available with an internally programmed over-voltage trip point or as an adjustable version programmed by two external resistors.
评论(0)
发评论
下载排行榜
