24AA014/24LC014 pdf datasheet
消耗积分:3 | 格式:rar | 大小:777 | 2008-08-07
五斤麻辣油
分享资料个
The Microchip Technology Inc. 24AA014/24LC014 is a
1 Kbit Serial Electrically Erasable PROM with operation
down to 1.8V. The device is organized as a single
block of 128 x 8-bit memory with a 2-wire serial interface.
Low-current design permits operation with typical
standby and active currents of only 1 μA and 1 mA,
respectively. The device has a page write capability for
up to 16 bytes of data. Functional address lines allow
the connection of up to eight 24AA014/24LC014
devices on the same bus for up to 8 Kbits of contiguous
EEPROM memory. The device is available in the
standard 8-pin PDIP, 8-pin SOIC (150 mil), TSSOP, 2x3
DFN and MSOP packages.
评论(0)
发评论
下载排行榜
