24AA174 pdf datasheet
消耗积分:2 | 格式:rar | 大小:666 | 2008-08-07
分享资料个
The Microchip Technology Inc. 24AA174 is a cascadable
16K bit Electrically Erasable PROM. The device is
organized as eight blocks of 256 x 8-bit memory with a
2-wire serial interface and provides a specially
addressed OTP (one-time programmable) 16 byte
security block. Low voltage design permits operation
down to 1.8 volts (end-of-life voltage for most popular
battery technologies) with standby and active currents
of only 5 μA and 1 mA respectively. The 24AA174 also
has a page-write capability for up to 16 bytes of data.
The 24AA174 is available in the standard 8-pin DIP and
8-lead surface mount SOIC packages.
The three select pins, A0, A1, and A2, function as chip
select inputs and allow up to eight devices to share a
common bus, for up to 128K bits total system
EEPROM.
评论(0)
发评论
下载排行榜
