The TMS320C6745 DSP combines low power and high precision to give designers the freedom to bring portability to audio, medical, industrial and other applications requiring the precision, wide dynamic range and time-to-market benefits of floating-point DSPs. Using three times less power than existing floating-point DSPs in today's market, the C674x devices deliver 24-/32-bit accuracy and are the industry's lowest power floating-point DSPs. Slated for sampling in Q4 2008, the power consumption ranges from 6 mW* in deep-sleep mode to 420 mW** total power in active mode.
Key Features:For detailed information on the TMS320C6745 floating-point DSP, download the TMS320C6745 technical brief
* Power use scenario - deep sleep: 0.95-V core, DSP clock OFF, all peripherals clock OFF, RTC ON, PLL disabled,25°C
** Power use scenario - active: 70% max load of CPU running at 300 MHz at 1.2V, mDDR 133 MHz/16 bit accessed 50% of the time, McBSP, SPI and GPIOs peripherals are active, 25°C
