TMS320C6747 pdf datasheet
消耗积分:10 | 格式:rar | 大小:1555 | 2008-08-07
王杰
分享资料个
The TMS320C6747 DSP combines low power and high precision to give designers the freedom to bring portability to audio, medical, industrial and other applications requiring the precision, wide dynamic range and time-to-market benefits of floating-point DSPs. Using three times less power than existing floating-point DSPs in today's market, the C674x devices deliver 24-/32-bit accuracy and are the industry's lowest power floating-point DSPs. Slated for sampling in Q4 2008, the power consumption ranges from 6 mW* in deep-sleep mode to 420 mW** total power in active mode.
Key Features:
  • Industry's lowest-power floating-point DSPs
  • High precision and wide dynamic range enabled through the 24-/32-bit accuracy of the floating-point DSP core
  • Portability for traditionally wired applications through low power and rich connectivity peripherals
  • Reduces system cost through high feature integration and low pricing starting at less than $11 USD @ 100u quantities
  • Up to 20× lower standby power and 1/3 the power consumption of existing floating-point devices
For detailed information on the TMS320C6747 floating-point DSP, download the TMS320C6747 technical brief
* Power use scenario - deep sleep: 0.95-V core, DSP clock OFF, all peripherals clock OFF, RTC ON, PLL disabled,25°C
** Power use scenario - active: 70% max load of CPU running at 300 MHz at 1.2V, mDDR 133 MHz/16 bit accessed 50% of the time, McBSP, SPI and GPIOs peripherals are active, 25°C
评论(1)
发评论
rong183 2012-06-20
0 回复 举报
怎么下载不了呢 收起回复
下载排行榜
全部1条评论
