俄罗斯方块——java源代码提供
消耗积分:10 | 格式:rar | 大小:278 | 2010-02-10
而无返还
分享资料个
俄罗斯方块——java源代码提供
import java.awt.*;
import java.awt.event.*;
//俄罗斯方块类
public class ERS_Block extends Frame{
public static boolean isPlay=false;
public static int level=1,score=0;
public static TextField scoreField,levelField;
public static MyTimer timer;
GameCanvas gameScr;
public static void main(String[] argus){
ERS_Block ers = new ERS_Block("俄罗斯方块游戏 V1.0 Author:Vincent");
WindowListener win_listener = new WinListener();
ers.addWindowListener(win_listener);
//俄罗斯方块类的构造方法
ERS_Block(String title){
super(title);
setSize(600,480);
setLayout(new GridLayout(1,2));
gameScr = new GameCanvas();
gameScr.addKeyListener(gameScr);
timer = new MyTimer(gameScr);
timer.setDaemon(true);
timer.start();
timer.suspend();
add(gameScr);
Panel rightScr = new Panel();
rightScr.setLayout(new GridLayout(2,1,0,30));
rightScr.setSize(120,500);
add(rightScr);
//右边信息窗体的布局
MyPanel infoScr = new MyPanel();
infoScr.setLayout(new GridLayout(4,1,0,5));
infoScr.setSize(120,300);
rightScr.add(infoScr);
//定义标签和初始值
Label scorep = new Label("分数:",Label.LEFT);
Label levelp = new Label("级数:",Label.LEFT);
scoreField = new TextField(8);
levelField = new TextField(8);
scoreField.setEditable(false);
levelField.setEditable(false);
infoScr.add(scorep);
infoScr.add(scoreField);
infoScr.add(levelp);
infoScr.add(levelField);
scorep.setSize(new Dimension(20,60));
scoreField.setSize(new Dimension(20,60));
levelp.setSize(new Dimension(20,60));
levelField.setSize(new Dimension(20,60));
scoreField.setText("0");
levelField.setText("1");
//右边控制按钮窗体的布局
MyPanel controlScr = new MyPanel();
controlScr.setLayout(new GridLayout(5,1,0,5));
rightScr.add(controlScr);
//定义按钮play
Button play_b = new Button("开始游戏");
play_b.setSize(new Dimension(50,200));
play_b.addActionListener(new Command(Command.button_play,gameScr));
//定义按钮Level UP
Button level_up_b = new Button("提高级数");
level_up_b.setSize(new Dimension(50,200));
level_up_b.addActionListener(new Command(Command.button_levelup,gameScr));
//定义按钮Level Down
Button level_down_b =new Button("降低级数");
level_down_b.setSize(new Dimension(50,200));
level_down_b.addActionListener(new Command(Command.button_leveldown,gameScr));
//定义按钮Level Pause
Button pause_b =new Button("游戏暂停");
pause_b.setSize(new Dimension(50,200));
pause_b.addActionListener(new Command(Command.button_pause,gameScr));
//定义按钮Quit
Button quit_b = new Button("退出游戏");
quit_b.setSize(new Dimension(50,200));
quit_b.addActionListener(new Command(Command.button_quit,gameScr));
controlScr.add(play_b);
controlScr.add(level_up_b);
controlScr.add(level_down_b);
controlScr.add(pause_b);
controlScr.add(quit_b);
setVisible(true);
gameScr.requestFocus();
//重写MyPanel类,使Panel的四周留空间
class MyPanel extends Panel{
public Insets getInsets(){
return new Insets(30,50,30,50);
//游戏画布类
class GameCanvas extends Canvas implements KeyListener{
final int unitSize = 30; //小方块边长
int rowNum; //正方格的行数
int columnNum; //正方格的列数
int maxAllowRowNum; //允许有多少行未削
int blockInitRow; //新出现块的起始行坐标
int blockInitCol; //新出现块的起始列坐标
int [][] scrArr; //屏幕数组
Block b; //对方快的引用
//画布类的构造方法
GameCanvas(){
rowNum = 15;
columnNum = 10;
maxAllowRowNum = rowNum - 2;
b = new Block(this);
blockInitRow = rowNum - 1;
blockInitCol = columnNum/2 - 2;
scrArr = new int [32][32];
//初始化屏幕,并将屏幕数组清零的方法
void initScr(){
for(int i=0;ifor (int j=0; jscrArr[j]=0;
b.reset();
repaint();
//重新刷新画布方法
public void paint(Graphics g){
for(int i = 0; i < rowNum; i++)
for(int j = 0; j < columnNum; j++)
drawUnit(i,j,scrArr[j]);
评论(0)
发评论
下载排行榜
