多重电枢绕组混合励磁风力发电系统并联运行并网控制策略:为了提高系统的可靠性和容错能力,针对多重电枢混合励磁发电机,提出了一种多重电枢直流侧电压关联运行的
控制方案。详细分析了单套逆变器数学模型和控制策略,运用CAN 通讯和上位机控制,实现多重逆变器并联运行并网,实
验结果与理论分析结果相吻合。
ABSTRACT: The paper proposes a novel control strategy that can make the DC voltage flexibly run in parallel based on the multiple armature-winding hybrid-excitation generator (MAHEG), which makes the system more reliable and more robust. The mathematical model and the control strategy for the grid-connected inverter is described and grid-connecting is realized via the CAN communication by the computer. The experimental results agree with the theoretical analyses.
关键词:多重电枢绕组混合励磁发电机;并联;数学模型;控制策略
KEY WORDS: MAHEG ; in parallel ; mathematical model; control strategy
