在汇编程序中灵活运用TSRs的程序库
; AMISUTIL.ASM Public Domain 1993 Ralf Brown
; You may do with this software whatever you want, but
; common courtesy dictates that you not remove my name
; from it.
; Utility functions to be called by the TSR's resident code
; Version 0.92
; LastEdit: 2/21/93
__DEFAULT_MODEL__ equ __TINY__
INCLUDE AMIS.MAC
TSRgroup@ byte
; Put the resident code into its own segment so that all the offsets are
; proper for the new location after copying it into a UMB or down into
; the PSP.
TSRcode@ byte
ASSUME CS:RESIDENT_CODE,DS:TGROUP,ES:NOTHING
; TSR's initialized data storage
TSRdata@
TSRdataEnd@
; TSR's uninitialized data storage
TSRbss@
cursor_pos label word
cursor_x db ?
cursor_y db ?
interrupted_cursorpos dw ?
display_page_attr label word
display_attr db ?
display_page db ?
screen_width db ?
window_upleft label word
window_left db ?
window_top db ?
window_lowright label word
window_right db ?
window_bottom db ?
window_size label word
window_width db ?
window_height db ?
screen_buffer_offset dw ?
window_name_offset dw ?
TSRbssEnd@
public TSR_GETKEY
TSR_GETKEY proc near
mov ah,11h ; keystroke available?
int 16h
jnz TSR_getkey_got_one ; if yes, get it, otherwise
int 28h ; give other TSRs a chance to do work
jmp TSR_GETKEY
TSR_getkey_got_one:
mov ah,10h ; get the keystroke
int 16h
ret
TSR_GETKEY endp
; exit: AX, BH, DX destroyed
public TSR_HOME_CURSOR
TSR_HOME_CURSOR proc near
xor dx,dx
;; fall through to TSR_MOVE_CURSOR ;;
TSR_HOME_CURSOR endp
; entry: DH = row, DL = column
public TSR_MOVE_CURSOR
TSR_MOVE_CURSOR proc near
ASSUME DS:TGROUP,ES:NOTHING
mov cursor_pos,dx
add dl,window_left
inc dl
mov al,window_right
dec al
cmp dl,al
jbe col_OK
mov dl,al
col_OK:
add dh,window_top
inc dh
mov al,window_bottom
dec al
cmp dh,al
jbe row_OK
mov dh,al
row_OK:
;; fall through to TSR_MOVE_CURSOR_ABS ;;
TSR_MOVE_CURSOR endp
TSR_MOVE_CURSOR_ABS proc near
mov bh,display_page
mov ah,2 ; BIOS move-cursor function
int 10h
ret
TSR_MOVE_CURSOR_ABS endp
; entry: AL = char
; exit: AH,BX,CX,DX destroyed
public TSR_PUT_CHAR
TSR_PUT_CHAR proc near
mov cx,1
;; fall through to TSR_PUT_LINE
TSR_PUT_CHAR endp
; entry: AL = char, CX = repeat count
; exit: AX,BX,CX,DX destroyed
public TSR_PUT_LINE
TSR_PUT_LINE proc near
add cursor_x,cl
mov bx,display_page_attr
mov ah,9
int 10h
mov al,cursor_x
cmp al,window_width
jb TSR_put_line_done
mov cursor_x,0
inc cursor_y
cmp al,window_height
dec cursor_y
call TSR_SCROLL_WINDOW
TSR_put_line_done:
mov dx,cursor_pos
jmp TSR_MOVE_CURSOR
TSR_PUT_LINE endp
; entry: DS:SI -> string
; exit: DS:SI -> byte after terminating NUL
public TSR_PUT_STRING
TSR_PUT_STRING proc near
lodsb
or al,al
jz TSR_put_string_done
call TSR_PUT_CHAR
jmp TSR_PUT_STRING
TSR_put_string_done:
TSR_PUT_STRING endp
; exit: AX,BX,CX destroyed
put_char_186 proc near
mov al,186 ; double vertical line
;; fall through to put_char_tty ;;
put_char_186 endp
; entry: AL = char
put_char_tty proc near
mov ah,0Eh
int 10h
ret
put_char_tty endp
public TSR_SAVE_SCREEN
TSR_SAVE_SCREEN proc near
mov ah,0Fh
int 10h ; get video mode and active page
mov display_page,bh
mov screen_width,ah
mov ah,3 ; get cursor position on page BH
int 10h
mov interrupted_cursorpos,dx
push ds
pop es
ASSUME ES:TGROUP
mov di,screen_buffer_offset
mov dh,window_top
save_screen_loop1:
mov dl,window_left
save_screen_loop2:
mov ah,2 ; set cursor position on page BH
int 10h
mov ah,8 ; read character&attribute on page BH
int 10h
cld
stosw ; and remember them for later restore
inc dl
cmp dl,window_right
jbe save_screen_loop2
inc dh
cmp dh,window_bottom
jbe save_screen_loop1
ret
TSR_SAVE_SCREEN endp
framed_window_hline proc near
push ax
call put_char_tty
mov cl,window_width
mov ch,0
dec cx
dec cx
js fwh_done
mov ax,(256*0Eh)+205
fwh_loop:
int 10h
loop fwh_loop
fwh_done:
pop ax
mov al,ah
jmp put_char_tty
framed_window_hline endp
public TSR_FRAMED_WINDOW
TSR_FRAMED_WINDOW proc near
mov dx,window_upleft
call TSR_MOVE_CURSOR_ABS
mov display_attr,0Fh ; bright white on black
mov ax,0BBC9h ; double upper left/right corners
call framed_window_hline
push si
inc dh
frame_loop:
mov si,dx
call put_char_186 ; double vertical bar
mov dx,si
mov dl,window_right
mov dx,si
inc dh
jb frame_loop
pop si
mov dl,window_left ; DH is already window_bottom
mov ax,0BCC8h ; double lower left/right corners
; frame is done, now add the title
inc dx
inc dx
mov si,window_name_offset
frame_title:
lodsb
or al,al
jz frame_title_done
call put_char_tty
jmp frame_title
frame_title_done:
call TSR_HOME_CURSOR
mov display_attr,07h ; dim white on black
;; fall through to TSR_CLEAR_WINDOW ;;
TSR_FRAMED_WINDOW endp
public TSR_CLEAR_WINDOW
TSR_CLEAR_WINDOW proc near
mov ax,0600h ; clear popup window area
scroll:
mov bh,display_attr
mov cx,window_upleft
add cx,0101h
mov dx,window_lowright
sub dx,0101h
int 10h
ret
TSR_CLEAR_WINDOW endp
public TSR_SCROLL_WINDOW
TSR_SCROLL_WINDOW proc near
mov ax,0601h
jmp scroll
TSR_SCROLL_WINDOW endp
public TSR_RESTORE_SCREEN
TSR_RESTORE_SCREEN proc near
mov si,screen_buffer_offset
mov dh,window_top
rest_screen_loop1:
mov dl,window_left
rest_screen_loop2:
push dx
mov ah,2
mov bh,display_page
int 10h ; set cursor position
cld
lodsw ; get character and attribute to restore
mov bl,ah ; BL <- attribute
mov cx,1
mov ah,9 ; write character&attribute
int 10h
pop dx
inc dl
cmp dl,window_right
jbe rest_screen_loop2
inc dh
jbe rest_screen_loop1
mov dx,interrupted_cursorpos
mov ah,2 ; restore cursor position
int 10h
ret
TSR_RESTORE_SCREEN endp
TSRcodeEnd@
_TEXT SEGMENT PUBLIC 'CODE'
ASSUME cs:_TEXT,ds:NOTHING,es:NOTHING,ss:NOTHING
IFDEF __TINY__
extrn TGROUP@:word
ENDIF
; entry: AX = upleft row,col
; BX = height, width
; CX = offset of screen buffer in TGROUP
; DX = offset of window title in TGROUP
public TSR_SET_WINDOW
TSR_SET_WINDOW proc DIST
ASSUME CS:_TEXT,DS:NOTHING,ES:NOTHING,SS:NOTHING
push ds
mov ds,TGROUP@
ASSUME DS:TGROUP
mov window_upleft,ax
mov window_size,bx
mov screen_buffer_offset,cx
mov window_name_offset,dx
dec bl
dec bh
add ax,bx
mov window_lowright,ax
pop ds
ASSUME DS:NOTHING
ret
TSR_SET_WINDOW endp
_TEXT ENDS
END
