Is there a problem updating firmware using USB interface? An intermittent problem occurs with firmware updates using the USB interface with several of the hand held test instruments. The list of instruments includes the MS2024A, MS2026A, MS2034, MS2036A, MS2717A/B, MS2718B, MS2719B, MS2721A/B, MS2723B, MS2724B, MS8911A/B, MT8220A and MT8222A. After the update is completed, the instrument may fail to boot properly. If you have an instrument that fails to boot after a failed firmware update, use the following steps to resolve the problem.
