CAT885-5通道电源监控器数据手册
消耗积分:3 | 格式:rar | 大小:221 | 2010-03-04
无人岛
分享资料个
The CAT885 is a five-channel power supply supervisory circuit with high reset thereshold accuracy and very low power consumption. The device features an open-drain output, active-low function with manual reset to perform basic system reset and monitoring functions for a wide range of electronic products. The CAT885 monitors five system voltages by maintaining a reset output active until all the power supply voltages exceed the specified trip values. The device then maintains the reset output in an active condition until the internal timer times out, which allows the system power supplies to stabilize.
评论(0)
发评论
下载排行榜
