SN74ALVC164245 IO电平转换英文资料,data
消耗积分:10 | 格式:rar | 大小:337 | 2010-03-11
自我清欢
分享资料个
16-BIT 2.5-V TO 3.3-V/3.3-V TO 5-V LEVEL-SHIFTING TRANSCEIVER WITH 3-STATE OUTPUTS
This 16-bit (dual-octal) noninverting bus transceiver
contains two separate supply rails. B port has VCCB,
which is set to operate at 3.3 V and 5 V. A port has
VCCA, which is set to operate at 2.5 V and 3.3 V. This
allows for translation from a 2.5-V to a 3.3-V
environment, and vice versa, or from a 3.3-V to a 5-V
environment, and vice versa.
The SN74ALVC164245 is designed for asynchronous
communication between data buses.
评论(0)
发评论
下载排行榜
