#include "msp430x13x.h"
void nop(void)
_NOP();
_NOP();
_NOP();
void start(void)
SCLEN &= (~(SDA+SCL));
_NOP();
_NOP();
_NOP();
SDAEN |= SDA;
SCLEN |= SCL;
return;
void stop(void)
SDAEN |= SDA;
SCLEN &= (~SCL);
SDAEN &= (~SDA);
return;
unsigned char ControlByte(int AddressByte)
unsigned char temp;
_BIC_SR(0X0001); //CLEAR SR 'C'
temp = (char)(AddressByte>>8);
temp <<= 1 ;
temp &= 0X0E;
temp += Code;
return temp;
int shout( unsigned char data )
unsigned char mask,i,temp;
unsigned char Value;
Value = data;
mask=0X80;
for (i=0;i<=7;i++){
temp = (Value & mask);
if( temp !=0 ){
SDAEN &= (~SDA);
SCLEN &= (~SCL);
if( !( SDAIN & SDA ) ){
return 1;
else {
SDAEN |= SDA ;
SCLEN &= (~SCL);
mask>>=1;
SCLEN |= SCL;
SDAEN &= (~SDA);
SCLEN &= (~SCL);
if ( !(SDAIN & SDA )){
// return 1;
SCLEN |= SCL;
return 0;
// 写 Number 个字节到 E2 中
int WriteBlock(int number,unsigned char *dataadr,unsigned char *e2adr)
unsigned char *p1;
int i;
unsigned char temp;
unsigned int aaa;
//unsigned char *temp1;
_DINT();
SDADAT &= (~(SCL+SDA));
start();
aaa = (int)(e2adr );
temp = ControlByte(aaa);
shout(temp);
shout( (int)(e2adr));
p1 = dataadr;
for (i=1;i<=8;i++) {
shout(*p1);
p1++;
stop();
_EINT();
//Write a block use the address and back..
return 0; //if error return 1 right return 0
// 写N * 8个字节
int WriteN8Byte(int Number)
unsigned char *e2adr,*dataadr;
unsigned int i,j;
//int WriteBlock(int number,unsigned char *dataadr,unsigned char *e2adr)
dataadr = (char*)0x200;
e2adr = (char*)0x00;
for( i=1;i<=Number;i++){
WriteBlock(8,dataadr,e2adr);
dataadr += 8;
e2adr += 8;
for (j=0;j<=3333;j++);
return 0;
//; Clock out an acknowledge bit (low).
//; SCL expected low on entry. Return with SCL, SDA low.
void Ack(void)
SDAEN |= SDA;
SCLEN &= ~SCL;
SCLEN |= SCL;
//; Clock out a negative acknowledge bit (high).
//; SCL expected low on entry. Return with SCL low, SDA high.
void Nak(void)
SDAEN &= ~SDA; //; NAK bit
SCLEN &= ~SCL; //; raise clock
SCLEN |= SCL; //; drop clock
//由E2 中 读8位 一个字节 数据
unsigned char shin(void)
int i;
unsigned char temp;
unsigned char Mask;
SDAEN &= ~SDA; // make SDA an input
temp =0;
//读8位数据
for( i=1;i<=8;i++) {
SCLEN &= ~SCL; //SCL = H
Mask = 0;
if (SDAIN &SDA)
Mask = 1;
else
Mask =0;
// Mask = SDAIN & SDA;
Mask <<= (8 - i);
temp ^= Mask;
SCLEN |= SCL;
return temp;
// 24c256 512 页 64字节 14-15bit Word Address!!!
// 读取N 个字节 到RAM 中
// 参数说明: number 读取的个数,dataadr,读到RAM 的地址?e2adr,E2地址
int ReadNByte(int number,unsigned char *dataadr,unsigned char *e2adr)
int i;
unsigned char *p;
unsigned char temp;
unsigned char temp1;
_DINT();
p=dataadr;
start();
temp = ControlByte((int)(e2adr ));
shout(temp);
shout((int)(e2adr ));
start();
temp |= 0X01;
shout(temp);
temp1=0;
for (i=1;i<=number;i++){
temp1 = shin();
*p++ = temp1;
Ack();
Nak();
stop();
_EINT();
return 0;
全部1条评论
