基于电源之34063芯片
消耗积分:0 | 格式:pdf | 大小:0.20 MB | 2018-08-04
芯锐技
分享资料个
  The MC34063A Series is a monolithic control circuit containing the primary functions required for DC–to–DC converters. These devices consist of an internal temperature compensated reference, comparator, controlled duty cycle oscillator with an active current limit circuit, driver and high current output switch. This series was specifically designed to be incorporated in Step–Down and Step–Up and Voltage–Inverting applications with a minimum number of external components. Refer to Application Notes AN920A/D and AN954/D for additional design information.
  • Operation from 3.0 V to 40 V Input
  • Low Standby Current • Current Limiting
  • Output Switch Current to 1.5 A
  • Output Voltage Adjustable
  • Frequency Operation to 100 kHz
  • Precision 2% Reference
评论(0)
发评论
下载排行榜
