MAX6953,pdf,datasheet,Matrix L
消耗积分:5 | 格式:rar | 大小:344 | 2010-03-28
分享资料个
The MAX6953 is a compact cathode-row display driver
that interfaces microprocessors to 5 ✕ 7 dot-matrix LED
displays through an I2C™-compatible serial interface.
The MAX6953 drives up to four digits (140 LEDs).
Included on-chip are an ASCII 104-character font, multiplex
scan circuitry, column and row drivers, and static
RAM that stores each digit, as well as font data for 24
user-definable characters. The segment current for the
LEDs is set by an internal digit-by-digit digital brightness
control.
The device includes a low-power shutdown mode, segment
blinking (synchronized across multiple drivers, if
desired), and a test mode that forces all LEDs on. The
LED drivers are slew-rate limited to reduce EMI.
For an SPI™-compatible version, refer to the MAX6952
data sheet. An EV kit is available for the MAX6952.
评论(0)
发评论
下载排行榜
