BFRP管材在节水灌溉工程中的应用研究
摘要: 围绕竹纤维增强塑料的组份材料特点, 以及仿照常规复合材料的热压法和渐进式树脂渗入法的制作工艺、材料及构件性能等进行研究与探讨, 显示了BFRP 管材在输水管道中的应用与开发有着一定的前景. 研究结果表明BFRP的性能良好, 经济效益明显. 可以作为许多土建工程的主、次承力构件. 同时认为还需解决一些重要技术问题以提高BFRP
的质量和性能, 进一步扩大应用范围.
关键词:BFRP; 节水灌溉; 制作工艺; 应用
Abstract :The material characteristic and manufacture process of BFRPis discussedinthe paper . The studyshows the functions of BFRP are perfect in water transportation pipes , whichcan be used as the main and the secondary bearing units in most engineering . It can be
predicted that the application and research of BFRPtubular in water-saving irrigation engineering can bring up the enormous economical benefits and social benefits .
