TLV5629,(8-Channel, 12-/10-/8-Bit, 2.7-V to 5.5-V, Low Pwr D
消耗积分:5 | 格式:rar | 大小:476 | 2010-06-07
王璐
分享资料个
The TLV5610, TLV5608, and TLV5629 are pin-compatible,eight-channel, 12-/10-/8-bit voltage output DACs each with a flexible serial interface. The serial interface allows glueless interface to TMS320 and SPI, QSPI, and Microwire serial ports. It is programmed with a 16-bit serial string containing 4 control and 12 data bits.
Additional features are a power-down mode, an LDAC input for simultaneous update of all eight DAC outputs, and a data output which can be used to cascade multiple devices.
The resistor string output voltage is buffered by a rail-to-rail output amplifier with a programmable settling time to allow the designer to optimize speed vs power dissipation. The buffered, high-impedance reference input can be connected to the supply voltage.
评论(1)
发评论
游客 2011-09-14
0 回复 举报
谢谢了 收起回复
下载排行榜
全部1条评论
