REF200,pdf(Dual Current Source
消耗积分:2 | 格式:rar | 大小:359 | 2010-06-13
向日葵的花季
分享资料个
DESCRIPTION
The REF200 combines three circuit building-blocks
on a single monolithic chip—two 100µA current
sources and a current mirror. The sections are
dielectrically isolated, making them completely
independent. Also, since the current sources are two-
terminal devices, they can be used equally well as
current sinks. The performance of each section is
individually measured and laser-trimmed to achieve
high accuracy at low cost.
The sections can be pin-strapped for currents of 50µA,
100µA, 200µA, 300µA or 400µA. External circuitry
can be used to obtain virtually any current. These and
many other circuit techniques are shown in the
Applications section of this Data Sheet.
The REF200 is available in plastic 8-pin mini-DIP
and SOIC packages.
评论(0)
发评论
下载排行榜
