The MAX98500 is a high-efficiency Class D audio amplifier that features an integrated boost converter, to deliver a constant output power over a wide range of battery supply voltages.
The boost converter operates at 2MHz, requiring only a small (2.2µH) external inductor and capacitor.
The automatic level control has a battery tracking function that reduces the output swing as the supply voltage drops, preventing collapse of battery voltage.
The amplifier has differential inputs and an internal fully differential design. The MAX98500 also features three gain settings (6dB, 15.5dB, and 20dB) that are selectable with a logic input.
The MAX98500 is available in a small, 0.5mm pitch 16-bump WLP package (2.1mm x 2.1mm). It is specified over the extended -40°C to +85°C temperature range.
