DSP Based Digital Controller f
消耗积分:2 | 格式:rar | 大小:300 | 2010-07-01
刘润生
分享资料个
 Abstract— The proliferation of highly sensitive power system
equipments demand high quality power supplied by utility.
Hence power quality has been very interesting research area
for past many years. Current harmonics are one of the most
significant power quality issue, which is usually resolved by
using shunt passive filters or shunt active filters. In this paper
ICOSφ algorithm [3] based shunt active filter is implemented
in analog circuit and tested for a nonlinear load. The test
results show that it can compensate for current harmonics.
The algorithm was implemented digitally by dsPIC 30F 4011
microcontroller with help of MPLAB C30 Compiler.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
