SN74ALVCH16820,pdf(3.3-V 10-BI
消耗积分:3 | 格式:rar | 大小:311 | 2010-07-26
分享资料个
This 10-bit flip-flop is designed for 1.65-V to 3.6-V VCC operation.
The flip-flops of the SN74ALVCH16820 are edge-triggered D-type flip-flops. On the positive transition of the clock (CLK) input, the device provides true data at the Q outputs.
A buffered output-enable (OE)\ input can be used to place the ten outputs in either a normal logic state (high or low logic level) or the high-impedance state. In the high-impedance state, the outputs neither load nor drive the bus lines significantly. The high-impedance state and increased drive provide the capability to drive bus lines without need for interface or pullup components.
OE\ input does not affect the internal operation of the flip-flops. Old data can be retained or new data can be entered while the outputs are in the high-impedance state.
评论(0)
发评论
下载排行榜
