Agilent Automotive Power Windo
消耗积分:2 | 格式:rar | 大小:280 | 2010-08-05
李杰
分享资料个
Abstract
Automotive power window regulator
tests require the use of accurate data
acquisition devices, as they cover a
wide range of parameters such as
window movement, acceleration of the
window movement in both directions,
maximum range of movement, torque
exerted at the start, the end stall
torque, and motor load characteristics.
This document provides an overview
of how the Agilent U2351A Series
USB-based data acquisition (DAQ)
device can be used for automotive
power window regulator testing by
mounting suitable sensors on the
power window to measure the various
parameters.
评论(0)
发评论
下载排行榜
