Agilent E3631A-E3634A Programm
消耗积分:5 | 格式:rar | 大小:137 | 2010-08-13
名士流
分享资料个
1. Two 4-digit voltage and current readings accurately
display actual or limit values simultaneously
2. Autotracking for 25 V outputs synchronization provides
required symmetrical voltages for easier and faster
setup
3. Output ON/OFF key allows you to enable or disable
power outputs, providing extra protection to the
device-under-test
4. Easy-to-use settings knob allows quick and easy
voltage or current settings
5. Resolution key provides fi ne setting on voltage or
current resolutions for better accuracy
6. Three independent outputs
(0 to + 6 V / 5 A and 0 to ± 25 V / 1 A) minimize any
interference between circuit-under-tests
Bias supply of ± 25 V allows you to set appropriate
operating points
7. Front-panel VFD (vacuum-fl uorescent display) shows
and monitors actual or limit values simultaneously
8. Delicate device-under-tests are provided with
overvoltage and overcurrent protection
9. Three completed power supply setup states can be
stored and recalled from internal non-volatile memory,
reducing your setup time
10. Remote sensing function eliminates errors in voltage
regulation due to voltage drop at load leads
11. Single output power supplies give you the fl exibility to
select from dual output ranges
• E3632A (0 to 15 V / 7A or 0 to 30 V / 4 A)
• E3633A (0 to 8 V / 20 A or 0 to 20 V / 10 A)
• E3634A (0 to 25 V / 7 A or 0 to 50 V / 4 A)
评论(0)
发评论
下载排行榜
