mm1414资料
消耗积分:5 | 格式:rar | 大小:239 | 2010-08-25
李鸿洋
分享资料个
This IC protects lithium ion batteries in the event of overcharge, overdischarge and overcurrent. It has the
following two functions: an overcurrent detection function that turns the external FET-SW off when a problem
occurs during charging, etc. and excess voltage is impressed on each battery for longer than a certain time,
and an overdischarge detection function that turns the external FET-SW off when battery voltage drops below
a certain voltage during discharge, in order to prevent battery overdischarge. When these functions operate,
the IC is put into low consumption current mode. It also has an overcurrent detection function that turns the
FET-SW off when excess current flows due to a short or the like.
评论(0)
发评论
下载排行榜
