ISO7240A,ISO7241A,ISO7242A,pdf
消耗积分:3 | 格式:rar | 大小:663 | 2010-08-26
分享资料个
See the Product Notification section. The ISO7240A, ISO7241A and ISO7242A are quad-channel digital isolators with multiple channel configurations and output enable functions. These devices have logic input and output buffers separated by TI’s silicon dioxide (SiO2) isolation barrier. Used in conjunction with isolated power supplies, these devices block high voltage, isolate grounds, and prevent noise currents from entering the local ground and interfering with or damaging sensitive circuitry.
The ISO7240A has all four channels in the same direction while the ISO7241A has three channels the same direction and one channel in opposition. The ISO7242A has two channels in each direction.
The devices have TTL input thresholds and a noise-filter at the input that prevents transient pulses from being passed to the output of the device.
评论(0)
发评论
下载排行榜
