The Primarion Di-POLTM PX7522 Power IC is a highly configurable Digital Point-of-Load (POL) Controller with two loops and two PWM outputs for use in high current buck converter topologies with either DCR or RDSon current sense applications. For the DCR current sense, the output range is from 0.5V to [Vcc – 0.9V] and for the RDSon current sense, the output range is from 0.5V to 8V. In dual-loop mode, the PX7522 supports two independent outputs with single phase control for each output. In single-loop mode, the PX7522 can provide a single output rail with up to two phases. Chip-to-chip current sharing with up to four phases can be interleaved synchronously for multiphase operation. The PX7522 provides PMBus™ POL power regulation and supports current sharing to balance the power supply currents. The PX7522 utilizes digital technology to implement all control functions, providing the ultimate in flexibility and stability. The PX7522 incorporates an industry standard PMBus™ serial interface for real-time system control. Through the serial interface, the power supply designer can quickly optimize designs while monitoring system performance without having to make any hardware adjustments. The PX7522 provides superior accuracy through internal calibration that measures and corrects current sense error sources upon startup. The PX7522 has programmable current sense temperature compensation that allows the designer to tailor the response for best accuracy over temperature. Superior accuracy reduces component count and solution cost.
