Applications
• X-Band Radar
• Satellite Communication Systems
General Description
The Qorvo TGP2109 is a 6-bit digital phase shifter fabricated on Qorvo’s high performance 0.15μm GaAs pHEMT process. It operates over 8 to 12 GHz and provides 360° of phase coverage with a LSB of 5.625°。 It also achieves a low RMS phase error of 4° with 6 dB of insertion loss.
The TGP2109 was developed for simply system integration. It uses positive only switch logic; eliminating the need for a negative voltage rail. In addition, both ports are matched to 50 ohms with DC blocking capacitors. Ease of use along with low insertion loss and a high degree of resolution makes the TGP2109 ideally suited for a variety of x-band phased array applications including commercial and military radars and phase array communication systems.
The device is lead-free and RoHS compliant.
Evaluation Boards are available upon request.
