The ML6102 is a group of high-precision and low-power voltage detectors. The ML6102 consists of a highly-accurate and low-power reference voltage source, a comparator, a hysteresis circuit, and an output driver. Detect voltage is very accurate and stable with N-channel open drain and CMOS, are available. Output Voltage is in inverted sense compared with ML61 series voltage detector.
