The AT8668S features a press-on/press-off switch that controls the microphone, muting it by 55 dB at 1,000 Hz. The circuitry also operates a light in the switch, powered by the 24-48V phantom source, to indicate when the mic is “on”. Regardless of the switch position, the actual mic operating voltage will be approximately 10-12V less than the phantom source voltage
