The LOG101 is a versatile integrated circuit that computes he logarithm or log ratio of an input current relative to a eference current. The LOG101 is tested over a wide dynamic range of input signals. In log ratio applications, a signal current can come rom a photodiode, and a reference current from a resistor in series with a precision external reference. The output signal at VOUT is trimmed to 1V per decade of input current allowing seven decades of input current dynamic ange. Low DC offset voltage and temperature drift allow accurate measurement of low-level signals over a wide environmental emperature range. The LOG101 is specified over the tem- perature range –5°C to +75°C, with operation over –40°C to +85°C.
