PC = programmer counter //程序计数器 ACC = accumulate // 累加器 PSW = programmer status word //程序状态字 SP = stack point //堆栈指针 DPTR = data point register //数据指针寄存器 IP = interrupt priority //中断优先级 IE = interrupt enable // 中断使能 TMOD = timer mode //定时器方式 ALE = address lock enalbe //地址锁存允许端 PSEN = programmer saving enable //程序存储器使能 EA = enable all (interrupt) //所有中断使能 PROG = progamme //程序 SFR = special function register //特殊功能寄存器 TCON = timer control //定时器控制 PCON = power control //电源控制
