UA723pdf(Precision Voltage regulator)
消耗积分:5 | 格式:rar | 大小:660 | 2010-10-23
分享资料个
The uA723 is a precision integrated-circuit voltage regulator, featuring high ripple rejection, excellent input and load regulation, excellent temperature stability, and low standby current. The circuit consists of a temperature-compensated reference-voltage amplifier, an error amplifier, a 150-mA output transistor, and an adjustable-output current limiter.
The uA723 is designed for use in positive or negative power supplies as a series, shunt, switching, or floating regulator. For output currents exceeding 150 mA, additional pass elements can be connected as shown in Figures 4 and 5.
The uA723C is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
