PT6939,pdf(11 Amp 5V/3.3V-Inpu
消耗积分:5 | 格式:rar | 大小:367 | 2010-11-16
分享资料个
The PT6935 Excalibur™ series of power modules are dual output integrated switching regulators (ISRs) designed to power the latest mixed signal ICs. The dual output provides power for both the digital I/O logic and a DSP core from a single module. Both output voltages are internally sequenced during power-up and power-down to comply with the requirements of the latest DSP chips. Each output is independently adjustable or can be set to at least one alternative bus voltage with a simple pin-strap. The modules are made available in a space-saving solderable case. Features include an output current limit and short-circuit protection.
评论(0)
发评论
下载排行榜
