在现代通信系统中,电话语音的频带被限制在300 Hz~4 kHz的范围内,带来了语音可懂度和自然度的降低。为了在不增加额外成本的前提下提高语音的可懂度和自然度,进行了电话语音频带扩展的研究。提出了一种改进的基于码本映射的语音带宽扩展算法:在码本映射的过程中,使用加权系数来得到映射码本。客观测试结果表明,用此算法得到的宽带语音的谱失真度比用一般的码本映射降低至少2%。主观测试结果表明,用此算法得到的宽带语音具有更好的可懂度和自然度。
- Abstract:
- In modern communication systems, the bandwidth of telephone speech is limited from 300Hz to 4 kHz, which reduces the intelligibility and naturalness of speech. Telephone speech bandwidth extension is researched to get wideband speech and to improve its intelligibility and naturalness, without increasing extra costs. This paper put forward an improved algorithm of speech bandwidth extension based on codebook mapping. In the process of codebook mapping, weighted coefficients were used to get mapping codebook. Objective tests show that spectral distortion of wideband speech obtained by this algorithm reduces at least 2%, comparing to conditional codebook mapping. Subjective tests show that the wideband speech obtained by this algorithm has better intelligibility and naturalness.
