基于Java Bean组件技术的模型表示
消耗积分:3 | 格式:rar | 大小:666 | 2010-11-24
张龙祥
分享资料个
为解决模型管理在模型重用、模型组合、跨平台调用等方面在目前网络应用环境下存在的问题,根据具体需求分析,指出现有表示方法的不足,在面向对象表示方法研究的基础上,结合组软件件技术的特点,比较了COM,CORBA, Bean 3种流行的组件技术后,提出将Java Bean组建技术应用到模型表示方法中。通过规范模型的具体设计方法,对模型组合条件进行讨论,然后设计了模型的表示框架和基本组成部分。最后通过模型表示框架流程说明其可行性。
Abstract:
 To solve problems in current web application environment such as model reuse, model combinations, cross-platform using in model management, specific needs were studied and shortcomings of existing methods were pointed. Based on Object-Oriented representation and component technology, and compared COM,CORBA,BEAN three main technologies, this paper proposed to take Java Bean component technology into model representation. By drafting model design specification, it discussed model combination conditions, and designed the model representation framework and basic elements. Finally, it verified its feasibility by model representation framework procedure.
评论(0)
发评论
下载排行榜
