xml specification
消耗积分:3 | 格式:rar | 大小:566 | 2008-10-07
分享资料个
This appendix has the complete, final XML 1.0
specification as published by the World Wide Web
consortium. This document has been reviewed by W3C
Members and other interested parties and has been endorsed
by the Director as a W3C Recommendation. It is a stable
document and may be used as reference material or cited as a
normative reference from another document. If any changes to
XML are required in the future (as they undoubtedly will be) a
new version number will be applied.
This document isn’t always easy reading. Precision is
preferred over clarity. However, when you’re banging your
head against the wall, and trying to decide whether the
problem is with your XML processor or with your XML code,
this is the deciding document. Therefore, it’s important to
have at least a cursory familiarity with it, and be able to find
things in it when you need to.
This document was primarily written by Tim Bray and C. M.
Sperberg-McQueen with assistance from many others credited
at the end of the document.
评论(0)
发评论
下载排行榜
