基于ADuC841的膜片钳放大器系统设计
消耗积分:3 | 格式:rar | 大小:979 | 2010-12-06
分享资料个
为降低成本和解决现有膜片钳放大器系统中PC机的干扰问题,研究了一种基于单片机的膜片钳放大器小系统。该系统采用ADI公司生产的ADuC841作为控制核心,并且配置相应的液晶显示模块LCM3202401。模拟电路部分采用高输入阻抗的AD8627实现微电流信号的采集,并由后级电路进行信号的放大和电阻电容的补偿。它具有硬件电路简单、体积小、使用方便的特点。既可以单独作为小系统实现采集和显示,也可以通过红外方式和PC机进行通讯,在PC机上进行信号的处理。
Abstract:
 In order to reduce cost and resolve the interferential problem with PC in existing patch clamp amplifiers, a small patch clamp amplifier system design based on microcontroller is studied. It adopts a new high performance microconverter ADuC841 by the ADI as the control core in the system, configuring a liquid crystal module LCM3202401. In the analog circuit, AD8627 with high input impedance is used to detect the low current,signal magnification, as well as resistance and capacitance compensation are accomplished by subsequent circuits. It has the advantage of simple hardware circuit design, small volume and convenient operation. It can either be used as an independent system to measure and show signal detected or transmit to PC by infrared ray.
评论(0)
发评论
下载排行榜
