TLE6210是Infineon公司推出的专门针对汽车防报死系统(Anti-lock Braking System,ABS)电子控制单元(Electric Control Unit,ECU)的系统级管理器件,完全满足ABS ECU的设计需要,由于集成度较高,提高了设计的可靠性并大幅度降低了ECU的硬件成本。主要介绍了TLE6210的内部结构、引脚功能以及作为系统级管理器件的典型应用。
- Abstract:
- TLE6210 is the system IC by Infineon corporation for the anti-lock braking system’s electric control unit of the mobile.It can satisfy the require of the ABS ECU.Because of its high integration,TLE6210 can improve the reliability and reduce the hardware cost. The structure,features and the typical application of TLE6210 are described.
