基于AT89C2051的温度监控系统的设计
消耗积分:10 | 格式:rar | 大小:711 | 2010-12-16
无人岛
分享资料个
采用单片机AT89C2051实现温度测量与控制,键盘和显示电路实现温度的设定、修改、清零以及当前温度值的显示,并对温度超过上下限进行报警。阐述了该系统设计的硬件和软件设计。
Abstract:
 The system of temperature measuring and controling is realized based on AT89C2051.The keyboard and display circuit is designed,which can be used for setting and modifying temperature value,resetting and displaying the present temperature value.At the same time the warning circuit is also designed in the system,which can deal with the alarm when temperature exceeds the upper limit and the lower limit.The hardware and software design of the system are explained.
评论(3)
发评论
448040218 2014-01-06
0 回复 举报
谢谢分享 收起回复
tianshizaizhe 2011-04-12
0 回复 举报
不错,谢谢! 收起回复
全部评论
下载排行榜
全部3条评论
