基于ISA总线的计算机与DSP的通信
消耗积分:5 | 格式:rar | 大小:839 | 2010-12-20
刘洋
分享资料个
在开放式数控系统结构模型的基础上,研究了基于ISA总线的DSP通信控制原理。采用中断方式完成了PC机和DSP之间的通信。介绍了以DriverWorks为工具开发ISA设备WDM驱动程序的方法,探讨了中断处理、驱动程序与应用程序之间的通信,简要说明了驱动程序的安装与调试。通过调试,系统设计运行稳定。
Abstract:
 The ISA bus and DSP correspondence control principle is investigated in the basis of the existing open architecture numerical control system.The interrupt method is used to realize the communication between PC and DSP based on the ISA bus.The methods of WDM driver exploitation for ISA device using Driver Works are introduced.The main process of driver program and the keys such as handle interrupt and the communication between the drivers and application are presented.And how to debug and install the drive is explained.
评论(2)
发评论
gaozhao211 2015-05-26
0 回复 举报
好文,果断下了! 收起回复
紫电魔焰 2015-01-21
0 回复 举报
好不容易找到一个 收起回复
下载排行榜
全部2条评论
