电子警察抓拍延时测量方法设计
消耗积分:3 | 格式:rar | 大小:629 | 2010-12-23
杨海清
分享资料个
由于图像型电子警察从前端感应设备检测到违章机动车,再到启动抓拍设备整个过程是有延时的,针对该抓拍延时的测量问题,设计一种以AT89S51单片机作为控制器的测量装置,应用数码管实现毫秒级计时显示。测量时,检测装置发出触发信号,单片机控制数码管计时,同时计算机读取触发信号并启动电子警察抓拍数码管图像,然后从抓拍的图像中读取准确的延时时间。
Abstract:
 In the image electronic police system, there is a delay between the front sensors have detected the vehicles pec-cancy and starting to take a snapshot.Aiming at this snapshot delay,the measurement equipment which used AT89S51 mi-crocontroller as MCU is designed ,seven segments LED can display time on the order of millisecond.If the sensor sends a trigger signal, the MCU will controll LED work.At the same time, the PC receives the signal and controls the camera to take a snapshot of the LED. The delay time could finally be read out form the images.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
