基于BF533的Linux网络驱动程序
消耗积分:3 | 格式:rar | 大小:664 | 2010-12-25
分享资料个
在分析Linux网络驱动程序体系结构的基础上,结合Linux2.6.18内核在ADSP鄄BF533开发板上移植编写CS8900A网卡驱动程序的实例,重点讨论了嵌入式Linux网络驱动程序的实现原理,并详细分析了程序代码的框架结构。
Abstract:
 The systematic structure of network driver based on Linux is analyzed in this paper.On the basis,the implemen-tation principle of network driver in embedded Linux is emphatically discussed through an example of realizing the trans-plant of CS8900A network interface driver using Linux2.6.18kernel based on experiment board ADSP-BF533,besides the detailed analysis of structure in the program code is given.
评论(0)
发评论
下载排行榜
